An error when I use roslaunch px4 mavros_posix_sitl.launch
I’ve compiled PX4 V1.15. By running make px4_sitl_default gazebo-classic, I can see and control the model in Gazebo normally. But when I use this command roslaunch px4 mavros_posix_sitl.launch I get an error
================================================================================REQUIRED process [sitl-2] has died!
process has died [pid 20270, exit code 255, cmd /home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/bin/px4 /home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/etc -s etc/init.d-posix/rcS __name:=sitl __log:=/home/a/.ros/log/9f11031a-79e4-11f0-b5f7-193575107c95/sitl-2.log].
log file: /home/a/.ros/log/9f11031a-79e4-11f0-b5f7-193575107c95/sitl-2*.log
Initiating shutdown!
I use gazebo11, Ubuntu20.04, Python 3.8.10。I tried reinstalling ROS, mavros, and PX4, but it didn’t work.The relevant content of my .bashrc file is as follows
source /opt/ros/noetic/setup.bash
source ~/catkin_ws/devel/setup.bash
source ~/catkin_ws/devel_isolated/setup.bash
source ~/Desktop/PX4-Autopilot/Tools/simulation/gazebo-classic/setup_gazebo.bash ~/Desktop/PX4-Autopilot/ ~/Desktop/PX4-Autopilot/build/px4_sitl_default
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/a/catkin_ws/devel/lib:/home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:~/Desktop/PX4-Autopilot
export ROS_PACKAGE_PATH=$ROS_PACKAGE_PATH:~/Desktop/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic
export GAZEBO_PLUGIN_PATH=$GAZEBO_PLUGIN_PATH:/home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/build_gazebo-classic
export GAZEBO_MODEL_PATH=$GAZEBO_MODEL_PATH:/home/a/Desktop/PX4-Autopilot/Tools/simulation/gazebo-classic/sitl_gazebo-classic/models
All prompt information is as follows
… logging to /home/a/.ros/log/9f11031a-79e4-11f0-b5f7-193575107c95/roslaunch-a-Legion-Y9000P-IRX8-20144.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server htt p://a-Legion-Y9000P-IRX8:37557/
SUMMARY
CLEAR PARAMETERS
  • /mavros/
PARAMETERS
  • /gazebo/enable_ros_network: True
  • /mavros/camera/frame_id: base_link
  • /mavros/cmd/use_comp_id_system_control: False
  • /mavros/conn/heartbeat_rate: 1.0
  • /mavros/wheel_odometry/wheel1/y: 0.15
  • /rosdistro: noetic
  • /rosversion: 1.17.4
  • /use_sim_time: True
NODES
gazebo (gazebo_ros/gzserver)
gazebo_gui (gazebo_ros/gzclient)
mavros (mavros/mavros_node)
sitl (px4/px4)
vehicle_spawn_a_Legion_Y9000P_IRX8_20144_4858227555632723743 (gazebo_ros/spawn_model)
auto-starting new master
process[master]: started with pid [20199]
ROS_MASTER_URI=ht tp://localhost:11311
setting /run_id to 9f11031a-79e4-11f0-b5f7-193575107c95
process[rosout-1]: started with pid [20253]
process[sitl-2]: started with pid [20270]
process[gazebo-3]: started with pid [20271]
[INFO] [1755268328.171841679]: Plugin landing_target loaded
[INFO] [1755268328.177902483]: Plugin landing_target initialized
[INFO] [1755268328.177974448]: Plugin local_position loaded
[INFO] [1755268328.180480910]: Plugin local_position initialized
[INFO] [1755268328.180531116]: Plugin log_transfer loaded
[INFO] [1755268328.181305074]: Plugin log_transfer initialized
[INFO] [1755268328.181334142]: Plugin mag_calibration_status loaded
[INFO] [1755268328.181596423]: Plugin mag_calibration_status initialized
[INFO] [1755268328.181643164]: Plugin manual_control loaded
[INFO] [1755268328.182316723]: Plugin manual_control initialized
[INFO] [1755268328.182347781]: Plugin mocap_pose_estimate loaded
[INFO] [1755268328.183898847]: Plugin mocap_pose_estimate initialized
[INFO] [1755268328.183940870]: Plugin mount_control loaded
[WARN] [1755268328.185466918]: Could not retrive negate_measured_roll parameter value, using default (0)
[WARN] [1755268328.185572281]: Could not retrive negate_measured_pitch parameter value, using default (0)
[WARN] [1755268328.185660981]: Could not retrive negate_measured_yaw parameter value, using default (0)
[WARN] [1755268328.185990155]: Could not retrive debounce_s parameter value, using default (4.000000)
[WARN] [1755268328.186079199]: Could not retrive err_threshold_deg parameter value, using default (10.000000)
[INFO] [1755268328.186094588]: Plugin mount_control initialized
[INFO] [1755268328.216944879]: Built-in SIMD instructions: SSE, SSE2
[INFO] [1755268328.216951307]: Built-in MAVLink package version: 2025.5.5
[INFO] [1755268328.216958551]: Known MAVLink dialects: common ardupilotmega ASLUAV AVSSUAS all csAirLink cubepilot development icarous loweheiser matrixpilot paparazzi standard storm32 uAvionix ualberta
[INFO] [1755268328.216965741]: MAVROS started. MY ID 1.240, TARGET ID 1.1
[mavros-6] killing on exit
[vehicle_spawn_a_Legion_Y9000P_IRX8_20144_4858227555632723743-5] killing on exit
[gazebo_gui-4] killing on exit
[gazebo-3] killing on exit
[sitl-2] killing on exit
File “/opt/ros/noetic/lib/gazebo_ros/spawn_model”, line 238, in
rospy.init_node(‘spawn_model’, anonymous=True)
File “/opt/ros/noetic/lib/python3/dist-packages/rospy/client.py”, line 323, in init_node
raise rospy.exceptions.ROSInitException(“init_node interrupted before it could complete”)
rospy.exceptions.ROSInitException: init_node interrupted before it could complete
[rosout-1] killing on exit
[master] killing on exit
shutting down processing monitor…
… shutting down processing monitor complete
done
I found the corresponding log information as follows. I only copied the content where the error occurred。
[rosmaster.master][INFO] 2025-08-15 22:34:23,023: -SUB [/mavros/actuator_control] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,023: -SUB [/mavros/adsb/send] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,023: -SUB [/mavros/cellular_status/status] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,023: -SUB [/mavros/companion_process/status] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/debug_value/send] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.threadpool][ERROR] 2025-08-15 22:34:23,024: Traceback (most recent call last):
File “/opt/ros/noetic/lib/python3/dist-packages/rosmaster/threadpool.py”, line 218, in run
result = cmd(*args)
File “/opt/ros/noetic/lib/python3/dist-packages/rosmaster/master_api.py”, line 210, in publisher_update_task
ret = xmlrpcapi(api).publisherUpdate(‘/master’, topic, pub_uris)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1109, in call
return self.__send(self.__name, args)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1450, in __request
response = self.__transport.request(
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1153, in request
return self.single_request(host, handler, request_body, verbose)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1169, in single_request
return self.parse_response(resp)
File “/usr/lib/python3.8/xmlrpc/client.py”, line 1341, in parse_response
return u.close()
File “/usr/lib/python3.8/xmlrpc/client.py”, line 655, in close
raise Fault(**self._stack[0])
xmlrpc.client.Fault: <Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/fake_gps/mocap/tf] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: publisherUpdate[/tf_static] → h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/global_position/set_gp_origin] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/home_position/home] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/gps_input/gps_input] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: publisherUpdate[/tf_static] → ht tp://a-Legion-Y9000P-IRX8:36345/ : sec=0.00, exception=<Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,024: -SUB [/mavros/gps_rtk/send_rtcm] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: -SUB [/mavros/global_position/gp_origin] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.threadpool][ERROR] 2025-08-15 22:34:23,025: Traceback (most recent call last):
result = cmd(*args)
return u.close()
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: publisherUpdate[/mavros/global_position/global] → ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: -SUB [/mavros/hil/state] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: -SUB [/mavros/hil/gps] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: publisherUpdate[/mavros/global_position/global] → ht tp://a-Legion-Y9000P-IRX8:36345/ : sec=0.00, exception=<Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: -SUB [/mavros/hil/imu_ned] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
result = cmd(*args)
return u.close()
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: -SUB [/mavros/hil/optical_flow] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,025: publisherUpdate[/mavros/global_position/gp_origin] → htt ://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: -SUB [/mavros/hil/rc_inputs] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: -SUB [/mavros/home_position/set] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: -SUB [/mavros/landing_target/pose] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: publisherUpdate[/mavros/global_position/gp_origin] → htt p://a-Legion-Y9000P-IRX8:36345/ : sec=0.00, exception=<Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: -SUB [/mavros/manual_control/send] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.threadpool][ERROR] 2025-08-15 22:34:23,026: Traceback (most recent call last):
result = cmd(*args)
return u.close()
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: -SUB [/mavros/mocap/pose] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,026: publisherUpdate[/mavros/home_position/home] → htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/mount_control/command] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/obstacle/send] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/odometry/out] /mavros http ://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: publisherUpdate[/mavros/home_position/home] → htt p://a-Legion-Y9000P-IRX8:36345/ : sec=0.00, exception=<Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/onboard_computer/status] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/play_tune] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.threadpool][ERROR] 2025-08-15 22:34:23,027: Traceback (most recent call last):
result = cmd(*args)
return u.close()
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: publisherUpdate[/mavros/local_position/pose] → ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,027: -SUB [/mavros/px4flow/raw/send] /mavros h ttp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/rc/override] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_accel/accel] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: publisherUpdate[/mavros/local_position/pose] → htt p://a-Legion-Y9000P-IRX8:36345/ : sec=0.00, exception=<Fault -1: ‘publisherUpdate: unknown method name’>
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_attitude/thrust] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_attitude/cmd_vel] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.threadpool][ERROR] 2025-08-15 22:34:23,028: Traceback (most recent call last):
result = cmd(*args)
return u.close()
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_position/local] /mavros htt p://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_position/global] /mavros h tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,028: -SUB [/mavros/setpoint_position/global_to_local] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
[rosmaster.master][INFO] 2025-08-15 22:34:23,029: -SUB [/mavros/global_position/global] /mavros ht tp://a-Legion-Y9000P-IRX8:36345/
I have spent a lot of time to solve this problem, I would be very grateful if you could help me solve it.If you need more information, I’ll add it.
What is there in this workspace?
If you don’t have any special requirements, you can try PX4 v1.14
Thanks for your reply,
The catkin_ws workspace contains some of my other projects, which have little to do with PX4.
I tried V1.14 but still got the same error. I tried to locate the location in the roslaunch file and found that the error was probably in the following code in posix_sitl.launch
<!-- PX4 SITL -->
<arg unless="$(arg interactive)" name="px4_command_arg1" value="-d"/>
<arg     if="$(arg interactive)" name="px4_command_arg1" value=""/>
<node name="sitl" pkg="px4" type="px4" output="screen"
    args="$(find px4)/build/px4_sitl_default/etc -s etc/init.d-posix/rcS $(arg px4_command_arg1)" required="true"/>
I tried writing the following launch file and got the same error:
NODES
    sitl (px4/px4)
process[master]: started with pid [21344]
ROS_MASTER_URI=http://localhost:11311
setting /run_id to b93d581a-8349-11f0-b017-c38f52cf8aa1
process[rosout-1]: started with pid [21385]
process[sitl-2]: started with pid [21392]
process has died [pid 21392, exit code 255, cmd /home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/bin/px4 /home/a/Desktop/PX4-Autopilot/build/px4_sitl_default/etc -s etc/init.d-posix/rcS __name:=sitl __log:=/home/a/.ros/log/b93d581a-8349-11f0-b017-c38f52cf8aa1/sitl-2.log].
log file: /home/a/.ros/log/b93d581a-8349-11f0-b017-c38f52cf8aa1/sitl-2*.log
shutting down processing monitor...
... shutting down processing monitor complete
done
