Hi there,
I was try to add rudder control to the HIL standard VTOL airframe, but it did not work. The following steps were what I have done, I edited the standard_vtol_hitl.sdf file.
At the rudder plugin, I added the <control_joint_name>
<plugin name="rudder" filename="libLiftDragPlugin.so">
<a0>0.0</a0>
<cla>4.752798721</cla>
<cda>0.6417112299</cda>
<cma>0.0.</cma>
<alpha_stall>0.3391428111</alpha_stall>
<cla_stall>-3.85</cla_stall>
<cda_stall>-0.9233984055</cda_stall>
<cma_stall>0</cma_stall>
<cp>-0.5 0 0.05</cp>
<area>0.02</area>
<air_density>1.2041</air_density>
<forward>1 0 0</forward>
<upward>0 1 0</upward>
<link_name>base_link</link_name>
rudder_joint
</control_joint_name>
<control_joint_rad_to_cl>4.0</control_joint_rad_to_cl>
<robotNamespace></robotNamespace>
<windSubTopic>world_wind</windSubTopic>
</plugin>
Then in the channel, I added the channel for rudder with input_index of 8:
<channel name="rudder">
<input_index>8</input_index>
<input_offset>0</input_offset>
<input_scaling>1</input_scaling>
<zero_position_disarmed>0</zero_position_disarmed>
<zero_position_armed>0</zero_position_armed>
<joint_control_type>position_kinematic</joint_control_type>
<joint_name>rudder_joint</joint_name>
</channel>
However, when I run the HIL, the rudder control is not performed when I input yaw control on my joystick. I have tried to change the input_index to 7, then I think it works, however I would lost my elevator control which also has input_index of 7.
I am wondering if I did any step wrong or I missed any step.
Thanks in advance!
Barry
