board : pixhawk4
i have calibrate my esc and it does work, but only one of them spin very slowly. i have check my circuit and re-calibrate my time,how can i do
youtube video describe problem : https://youtu.be/NsUVBbc1TsM
board : pixhawk4
Switch this ESC with another one located on the same vehicle to determine if the ESC or the PX4 setup of the ESC is the issue.
Omega8
It seems like one wire from ESC to motor came loose.
Other (more difficult to fix) causes:
As @Omega8 mentioned. Switching motors, ESC, PWM outputs may help to find an issue or failed component.
thx,i have found my problem
one of my screw stuck my moter cause short circuit
