We offer 28 payloads with same stardard connector,we call it quick-release connector.
Z40 is a poplular payload for Inspection,Public Saftey ,etc.Since it has 40x zoom lens, plus high precision gimbal stabilizer with special double shock-absorber mechanic system, can easily spot a target about 1km away, and capture the clear and detailed photosof someone, with the object tracking function, the camera will have the object focused on always in the center of the video by the help of the 3 axis gimbal.
Specs:
Weight: 850g
Video Format: H264 MP4, 4K
Photo Format: JPEG
Lens: 20x optical zoom (20x Optical and 2x digital), F1.8~F3.6
External Storage: SD(512M-2GB); SDHC(4GB-32GB); SDXC(48GB-128GB)
Gimbal control range: Pitch:-100°~45°; Yaw:-170°~170°
Tolerance while hold: ±0.01°
Tolerance while cruising: ±0.05°
1. 40x zoom
Easily spot a target 1km away.
2. Object tracking
Target will always stay in the center of the video, can’t never get out of there
3. 3 Axis stabilizing gimbal
It prevents the detail loss of the photo by stabilizing the camera. Capturing a full detailed face of suspect is an easy job
4. Fast attachment
Standard connector makes it easy to be attached within 30 seconds.
