4 bench measurement methods to evaluate BLDC motor performance before PX4 integration
Fellow drone engineers,
When integrating custom industrial multirotor power systems with PX4, many teams only test motor thrust at full throttle and ignore low-load consistency, which leads to persistent hover oscillation and high vibration logs later. I’ve summed up four simple lab bench checks to qualify brushless motors before mounting to airframes, no advanced dynamometer required.
  1. Three-phase winding resistance matching test
    Use multimeter to measure AB/BC/CA resistance. For long-flight industrial platforms, total phase difference should stay under 4%; larger deviation creates uneven current draw under steady PX4 mixer output.
  2. Torque ripple drag test
    Short all three motor leads, rotate bell evenly by hand. Irregular magnetic drag indicates uneven stator air gap, which generates fixed-frequency vibration visible on gyro FFT plots.
  3. Continuous low-throttle thermal balance test
    Drive motor at 30% fixed throttle via ESC for 10 mins; uneven heating between multiple same-model motors means inconsistent wire gauge or magnet grade, degrading long-endurance flight stability.
  4. Cold vs hot thrust deviation comparison
    Record static thrust at 25℃ ambient and after 30 mins continuous operation. Motors with low-grade magnets lose over 12% thrust after heating, causing PX4 attitude compensation drift.
Quick community question: Does your team implement mandatory motor electrical testing before PX4 tuning, or only troubleshoot vibration issues after flight? I’m building a standard pre-flight motor qualification checklist for heavy-payload UAV fleets.
