First of all, I’m just trying to learn the code, so you should take my advice and guiding taken with a grain of salt.
You can set different maps in The APPLICATION SETTINGS > GENERAL tab, under MAP PROVIDER.
So we start in MainWindowInner.qml. In the app we should go to the Application Settings tab in the main toolbar. So checking the qml, we find there is defined a custom type MainToolBar with id toolBar and defined as the main UI. We so, check MainToolBar.qml and get a QGCToolBarButton custom type:
QGCToolBarButton {
anchors.top: parent.top
anchors.bottom: parent.bottom
exclusiveGroup: mainActionGroup
source: "/res/QGCLogoWhite"
logo: true
onClicked: toolBar.showSettingsView()
visible: !QGroundControl.corePlugin.options.combineSettingsAndSetup
So back to MainWindowInner.qml and see that onShowSettingsView points to mainWindow.showSettingsView:
function showSettingsView() {
rootLoader.sourceComponent = null
if(currentPopUp) {
currentPopUp.close()
//-- In settings view, the full height is available. Set to 0 so it is ignored.
ScreenTools.availableHeight = 0
hideAllViews()
if (settingsViewLoader.source != _settingsViewSource) {
settingsViewLoader.source = _settingsViewSource
settingsViewLoader.visible = true
toolBar.checkSettingsButton()
_settingsViewSource is a property string that points to “AppSettings.qml”, so there we go. Here we have a rectangle that holds a QGCFlickable, where a Repeater (http://doc.qt.io/qt-5/qml-qtquick-repeater.html) instantiates a number of QGCButton type components using a model:
model: QGroundControl.corePlugin.settingsPages
So now, based on how C++ integrates with QML, we have to search, in this case, for a Q_PROPERTY called settingsPage. In my case, a grep search through the code takes me to QGCCorePlugin.h were we find:
Q_PROPERTY(QVariantList settingsPages READ settingsPages NOTIFY settingsPagesChanged)
So, lets take a look at that code in QGCCorePlugin.cc:
QVariantList &QGCCorePlugin::settingsPages()
if(!_p->pGeneral) {
_p->pGeneral = new QmlComponentInfo(tr(“General”),
QUrl::fromUserInput(“qrc:/qml/GeneralSettings.qml”),
QUrl::fromUserInput(“qrc:/res/gear-white.svg”));
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pGeneral));
_p->pCommLinks = new QmlComponentInfo(tr(“Comm Links”),
QUrl::fromUserInput(“qrc:/qml/LinkSettings.qml”),
QUrl::fromUserInput(“qrc:/res/waves.svg”));
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pCommLinks));
_p->pOfflineMaps = new QmlComponentInfo(tr(“Offline Maps”),
QUrl::fromUserInput(“qrc:/qml/OfflineMap.qml”),
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pOfflineMaps));
_p->pMAVLink = new QmlComponentInfo(tr(“MAVLink”),
QUrl::fromUserInput(“qrc:/qml/MavlinkSettings.qml”),
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pMAVLink));
_p->pConsole = new QmlComponentInfo(tr(“Console”),
QUrl::fromUserInput(“qrc:/qml/QGroundControl/Controls/AppMessages.qml”));
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pConsole));
#if defined(QT_DEBUG)
//-- These are always present on Debug builds
_p->pMockLink = new QmlComponentInfo(tr(“Mock Link”),
QUrl::fromUserInput(“qrc:/qml/MockLink.qml”));
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pMockLink));
_p->pDebug = new QmlComponentInfo(tr(“Debug”),
QUrl::fromUserInput(“qrc:/qml/DebugWindow.qml”));
_p->settingsList.append(QVariant::fromValue((QmlComponentInfo*)_p->pDebug));
#endif
The code is pointing us to GeneralSettings.qml.
//-- Map Provider
Row {
spacing: ScreenTools.defaultFontPixelWidth
visible: _mapProvider.visible
QGCLabel {
text: qsTr("Map Provider:")
width: _labelWidth
anchors.verticalCenter: parent.verticalCenter
FactComboBox {
width: _editFieldWidth
fact: _mapProvider
indexModel: false
We have a Fact defined:
property Fact _mapProvider: QGroundControl.settingsManager.flightMapSettings.mapProvider
So here is where map provider is defined. But we dont want to know who is the provider, but where its implemented the flight map. But now we know how the app calls to get the name of the map he wants to provide. So another grep search:
jguillen@HarryPotter:~/workspace/qgroundcontrol/src$ grep -r “QGroundControl.settingsManager.flightMapSettings.mapProvider” .
./ui/preferences/GeneralSettings.qml: property Fact _mapProvider: QGroundControl.settingsManager.flightMapSettings.mapProvider
./FlightMap/FlightMap.qml: target: QGroundControl.settingsManager.flightMapSettings.mapProvider
So we open FlightMap.qml and find that has a Map QML type (Map QML Type | Qt Location 5.15.16). You can follow from here.
Good luck
