Hi
thank you for the info.
Can you please advice with respect to which radio telemetry have you considered this config setting.
Are you telling me to separately wire the left and right ailerons to Main 1 and 2 of the pixhawk orange cube respectively. So only signal wire is required in this case as i plan to provide the power through a separate BEC. Please confirm
You can certainly use a Y-cable and just plug in to Main 1 or 2. Just make sure the your aileron directions are correct. Personally I prefer separate servos.
Yes, just signal but I usually just remove the power (red) wire and use both ground (blk) and signal (wht or yel).
