Hi there,
i need some help about format for my homemade serial link.
I am using sprintf() to do a string from a float data coming from sensor_combined topic of UORB then I send it with write() function.
Here is my code : (See last function myserial_thread_main)
* Copyright (c) 2012-2016 PX4 Development Team. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name PX4 nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* @file myserial.c
* Homemade serial link
* @author Leroy Theophile - leroy.theophile@gmail.com
#include <px4_config.h>
#include <px4_tasks.h>
#include <px4_posix.h>
#include <px4_log.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdio.h>
#include <stdarg.h>
#include <poll.h>
#include <string.h>
#include <math.h>
#include <termios.h>
#include <unistd.h>
#include <stdbool.h>
#include <errno.h>
#include <drivers/drv_hrt.h>
#include <uORB/uORB.h>
#include <uORB/topics/sensor_combined.h>
* Get values from sensors
void getValue(double *data);
* Main loop of daemon
int myserial_thread_main(int argc, char *argv[]);
* Print the correct usage.
static void usage(const char *reason);
int set_uart_baudrate(const int fd, unsigned int baud);
static int uart_init(char * uart_name);
__EXPORT int myserial_main(int argc, char *argv[]);
/* static variables */
static bool thread_should_exit = false; /**< Daemon exit flag */
static bool thread_running = false; /**< Daemon status flag */
static int deamon_task; /**< Handle of deamon task / thread */
int speed;
switch (baud) {
case 9600: speed = B9600; break;
case 19200: speed = B19200; break;
case 38400: speed = B38400; break;
case 57600: speed = B57600; break;
case 115200: speed = B115200; break;
default:
warnx("ERR: baudrate: %d\n", baud);
return -EINVAL;
struct termios uart_config;
int termios_state;
/* fill the struct for the new configuration */
tcgetattr(fd, &uart_config);
/* clear ONLCR flag (which appends a CR for every LF) */
uart_config.c_oflag &= ~ONLCR;
/* no parity, one stop bit */
uart_config.c_cflag &= ~(CSTOPB | PARENB);
/* set baud rate */
if ((termios_state = cfsetispeed(&uart_config, speed)) < 0) {
warnx("ERR: %d (cfsetispeed)\n", termios_state);
return false;
if ((termios_state = cfsetospeed(&uart_config, speed)) < 0) {
warnx("ERR: %d (cfsetospeed)\n", termios_state);
return false;
if ((termios_state = tcsetattr(fd, TCSANOW, &uart_config)) < 0) {
warnx("ERR: %d (tcsetattr)\n", termios_state);
return false;
return true;
int serial_fd = open(uart_name, O_RDWR | O_NOCTTY);
if (serial_fd < 0) {
err(1, "failed to open port: %s", uart_name);
return false;
return serial_fd;
void
if (reason) {
fprintf(stderr, "%s\n", reason);
fprintf(stderr, "usage: myserial {start|stop}\n\n");
exit(1);
int
if (argc < 2) {
usage("missing command");
if (!strcmp(argv[1], "start")) {
if (thread_running) {
warnx("running");
/* this is not an error */
exit(0);
deamon_task = px4_task_spawn_cmd("myserial",
SCHED_DEFAULT,
SCHED_PRIORITY_DEFAULT,
3000,
myserial_thread_main,
(char * const *)&argv[0]);
thread_running = true;
exit(0);
if (!strcmp(argv[1], "stop")) {
thread_should_exit = true;
exit(0);
if (!strcmp(argv[1], "status")) {
warnx("running");
} else {
warnx("not started");
exit(0);
return 0;
int
char str[500]={0};
//UART open
int uart = uart_init("/dev/ttyS6");
if(false == uart)return -1;
if(false == set_uart_baudrate(uart,9600)){
printf("[YCM]set_uart_baudrate is failed\n");
return -1;
printf("[YCM]uart init is successful\n");
//QUEUE open -- does not work
//mqd_t mqret = mq_open("xQueue",O_RDONLY);
//UORB request
/* subscribe to sensor_combined topic */
int sensor_sub_fd = orb_subscribe(ORB_ID(sensor_combined));
/* limit the update rate to 5 Hz */
orb_set_interval(sensor_sub_fd, 200);
px4_pollfd_struct_t fds[] = {
{ .fd = sensor_sub_fd, .events = POLLIN },
/* there could be more file descriptors here, in the form like:
* { .fd = other_sub_fd, .events = POLLIN },
//main thread loop
while (!thread_should_exit) {
//Receive from message queue "xQueue"
// mq_receive(mqret, (void *) data, sizeof(data),NULL);
int poll_ret = px4_poll(fds, 1, 1000);
if(poll_ret > 0){
if (fds[0].revents & POLLIN) {
/* obtained data for the first file descriptor */
struct sensor_combined_s raw;
/* copy sensors raw data into local buffer */
orb_copy(ORB_ID(sensor_combined), sensor_sub_fd, &raw);
for(int i=0;i<6;i++){
switch(i){
case 0:
sprintf(str, "Ax %8.4f",(double)raw.accelerometer_m_s2[0]);
break;
case 1:
sprintf(str, "Ay %8.4f",(double)raw.accelerometer_m_s2[1]);
break;
case 2:
sprintf(str, "Az %8.4f",(double)raw.accelerometer_m_s2[2]);
break;
case 3:
sprintf(str, "Gx %8.4f",(double)raw.gyro_rad[0]);
break;
case 4:
sprintf(str, "Gy %8.4f",(double)raw.gyro_rad[1]);
break;
case 5:
sprintf(str, "Gz %8.4f",(double)raw.gyro_rad[2]);
break;
PX4_INFO("%s",str);
write(uart, str, 1);
close(uart);
return 0;
The problem is that the formating is corect on the nuttx shell console debuger but when it goes to the serial link on tty6 the formating of the data seems wrong, it printf only the first char of the string … any idea ?
serial link to pc on SERIAL 4 (ttyS6)
nuttx shell debuger
______________________________ EDIT [SOLVED]
Ok it was because write function is a “UART PUTS CHAR” type of function and not a “UART PUT STRING”, A loop and its solved
for(int j=0;j<sizeof(str);j++){
c = str[j];
write(uart, &c, 1);
