Hi there,
I want to plan my mission without Qground control i.e. manually sending co-ordinates via Rpi without Mission Planner.
Is it possible to do that?
Thanks in advance
Yes! Look at dronecode SDK and the wiki section on companion computer.
Could you please explain because I’m a complete newbie.
You will have quite a bit of reading to do unfortunately. I suggest reading the Dronecode SDK docs. Try to run the example in simulation.
