The command is a MAV_CMD_SET_MESSAGE_INTERVAL (511) supposed to ask my drone to send me a SCALED_IMU (#26) message at an interval of 1 second (100000 us).
The thing is I send this command multiple times but I do not receive any SCALED_IMU (#26) message in return.
I also tried with the GenerateMAVLinkPacket10 method and with MAVLink.mavlink_command_long_t() instead, still nothing.
I understood what went wrong : It was the broadcasting (target_system = 0) not working so I had to put it to 1 (corresponding to the sysid of my drone).
However I have a second issue : it seems that the C# MAVLink librairy has a bug because everything I put in value or parameter of a message/command is interpreted as the int equivalent of the float, not the float itself, ie :
When i put for example 1.0f as a param_value, I see on QGroundControl that my value has been changed to 1065353216, which is the int equivalent of my float (as described here : Why is 1.0f in C code represented as 1065353216 in the generated assembly? - Stack Overflow)
It works as intended. Your param type is INT32, so the binary data at param_value is interpreted as 32-bit signed integer.
P.S. If you are asking for help with something you downloaded from the Internet, it would be nice to add a link to the NuGet to understand what you are using.
