Hi, I am learning about the px4 framework. When reading the makefile, there are two regular expressions in it that make me a little confused.
RESULT = $(shell [ -f .github/workflows/compile_${1}.yml ] && cat .github/workflows/compile_${1}.yml | sed -E 's|[[:space:]]+(.*),|check_\1|g' | grep check_${2})
j := $(shell ps T | sed -n 's|.*$(MAKE_PID).*$(MAKE).* \(-j\|--jobs\) *\([0-9][0-9]*\).*|\2|p')
My question is:
I studied the
sed
command on google, and learned that thesed
command uses\
separator in script to separate different parts such as:s\xxxx\xxxxx\g
. But in the first expression, it uses|
In the second expression, the ragular expression uses
\( xxx \)
as the capture group brackets instead of(xxxx)
When I run make xxx
, it works well. That makes me confused.
I run make -j16 -n
, j
is null. So I changed the expression as:
$(shell ps T | sed -r -n 's|.*$(MAKE_PID).*$(MAKE).* (-j\|--jobs) *([0-9][0-9]*).*|\2|p')")
The result changed to 16.
