Here is a very high level and non-exhaustive list of new features added to QGroundControl in version 4.0. Not to mention the large number of bug fixes in this release and Iām sure we lost track on listing some new features which were added along the way!
Note The format for Settings in QGC had to change in this release. Which means all QGC settings will be reset to defaults.
Settings
Language: Allow selection of language
ArduPilot
Mavlink: Configurable stream rate settings
Setup
Joystick
New joystick setup ui
Ability to configure held button to single or repeated action
ArduPilot
Motor Test
Plan
Create Plan from template with wizard like progression for completing full Plan.
Survey: Save commonly used settings as a Preset
Polygon editing
New editing tools ui
Support for tracing a polygon from map locations
ArduPilot
Support for GeoFence and Rally Points using latest firmwares and mavlink v2
Fly
Click to ROI support
Added support for connecting to ADSB SBS server. Adds support for ADSB data from USB SDR Dongle running ādump1090 --netā for example.
Ability to turn on Heading to home, COG and Next Waypoint heading indicators in Compass.
Video
Add support for h.265 video streams
Vehicle type specific pre-flight checklists. Turn on from Settings.
Analyze
New Mavlink Inspector which includes charting support. Supported on all builds including Android and iOS.
General
Released Windows build are now 64 bit only
Log Replay: Ability to specify replay speed
ArduPilot
Improved support for chibios firmwares and ArduPilot bootloader with respect to flashing and auto-connect.
Don, is there any backwards compatibility expected with previous version of PX4 firmware such as v1.9.2? Or is it assumed to be running PX4 v1.10 or later with QGC 4.0?
You can usually go back fairly far without problems with PX4. Some vehicle setup may freak out because of missing params.
Also FYI: With ArduPilot itās a little better in that the parameter name changes are tracked and fixed up on the fly for old versions. At least up to a certain point. QGC will tell you if you are using a version older than it supports.
You mentioned setup motortest for Ardupilotā¦
Is motortest for px4 (not Adru) fully functional? Eg. The different barsliders for each motor, to test them individually?
