In the process of setting up a hexacopter I ran into an issue calibrating the RC transmitter. When everything is turned on QGround Control does not recognize it and gives the error message “Please turn your transmitter”. The transmitter, a T6K-V3S, is indeed turned on and is paired with my Futaba R3006SB, which is connected to the PX4 with the SBus mode turned on. The only advice I’ve found about this issue is about the plug being installed correctly, which I checked.
Thoughts?
