PX4 Sync / Q&A: June 12, 2024
Agenda
  • Announcements
  • Release Discussion
  • Q&A
Announcements
Release Discussion
Q&A
@farhang asked how the situation is with this PR
recommended to bring this on a specific hardware and use case since each end user requires different specific settings.
@dannytoone
Some changes might be needed so that it is generalized to be merged.
@thomasfrans
https://github.com/PX4/PX4-Autopilot/pull/22904
@Rowan_Dempster asked about how to handle ekf replay and timestamps
@dagar and @bresch recommended to add logging ekf replay at the boot or prior to the arming couple seconds. Also maybe a more general way is available . EKF Reply overhaul PR maybe expected from dagar.
@bresch recommended to try this PR which is tested on hardware:
@AlexKlimaj will test it .
@dagar
When is px4 1.15 released?
Is there a reason for the delay in the release of version 1.15.0 stable? If a new release date has been set, I would like to know it.
@realstone1 @kiti1013
You could use
until the release tag is cut and can be done directly via QGC!
