Hello TexAcoon
I suppose you use USB Connector ?
What is happen after this (on your computer know the USB port, the led on Pixhawk give you some information) ?
Serge
Hi Serge,
With the PX4 blank I am having to load the programming via J-Link debugger …
With the PX4 plugged in usb I’m not getting anything showing on my usb port on my computer BUT I see the J-link connection … When I try to run the prgram from JLink commander it does not connect to device… I believe thats because the PX4 has something wrong with it … OR there again it may be something else thats not working correctly (Hey! could be the operator LOL!)
Since I wrote this post … I have tried several options to get it to work … I still do not get a connection to the PX4 … This is a bit difficult to determine when you have four components you are having to work through and not sure which one may be bad …
Found my problem … My issue was with uploading program using the J-Link / Debugger/ PC wiring issue. The wires (connectors) that connects between the debugger and PX4 connection was bad. I ended up using a meter to check from connector to connector point until I found the red wire was not showing continuity … I worked the wire to see if it would make up and sure enough it did … Had to tape the wire to the table top and positon the PX4 around running J-LINK Commander until it uploaded the program to the PX4 … WHOA! What a pain in the A$$ that was! …
