I am going through the schematics of PIXRACER-V1-R15.pdf for magnetic sensor(LIS3MDL) connectivity on SPI bus. link below
As per OEM(ST) the sensor needs dedicated SPI connectivity from controller for communication or use it in I2C mode.
howvever the design in PIXRACER-V1-R15.pdf uses Share SPI bus with MPU-9250, ICM-20602 and LIS3MDL.
Is it correct any change is done in final product.
