Good day to everyone. Consultation is required on the following question: Is the Holybro Pixhawk 6C flight controller compatible with the Tekko32 4IN1 35A speed controllers?
Yes, it is. But you will need to make your own cable to connect it.
Hi, thanks for the reply! I’m going to build a VTOL based on Skywalker X8, so I’m building a configuration. Can you tell us more about this cable? And yes, can I set up this controller via a PC, and not with the sticks of the control panel?
Hi. This question is relevant to me.
