I’ve got a pixhawk mini 4 using mission planner. Went through the setup and calibration. It powers up and will connect with mission planner (via usb). I force arm in MP but when I throttle up the motors wont turn. I must be missing a step(s).
Seeing 3 lights:
Power: Solid green
B/E: Flashing red (2 flashes)
ACT: Rapid flashing blue (17ish flashes)
I scoured YouTube for tutorials but all are on Pixhawk (not mini). Any setup documentation, videos or troubleshooting tips would be greatly appreciated.
Safety switch is probably enabled but either not pressed or not fitted. For help with Missionplanner and ArduPilot, better to head over to discuss.ardupilot.org
Thanks. Where does the safety switch plugin on the 4 mini? Is it the port on the side next to the USB? Is the switch purchased separately, seems like something that should be included?
Is there a comprehensive tutorial on youtube that folks are using? Feel like i’m piecing together info to stumble through setup, but imagine there is a tutorial somewhere?
