Hello everyone,
I am experiencing an issue with the parameter import functionality in PX4 via QGroundControl. I have noticed that not all parameters are set correctly after import_from_file feature.
To provide more details, I am attaching to this post a report comparing the two parameter files. In this report, you can see that some parameters are not imported as they should, due to there are several differences, which is affecting the behavior of my configuration.
The process has been:
- CubeOrange factory reset
- Export file0
- Import file0
- Export file0_b
- Compare file0 & file0_b
Has anyone had a similar experience or know what could be causing this problem? I would appreciate any suggestions or advice to solve this problem.
QGC_Import_report.pdf (287.7 KB)
Thank you in advance for your help!
Greetings,
