I’m trying to read heartbeat messages from my PX4 6X but unfortunately I can’t read any messages. I have connected the Telem2 Port to my Arduino
TX of the PX4 to the Arduino RX pin
GND - GND
This is my code:
#include <mavlink.h>
const int ledPin = 13;
void setup() {
Serial.begin(57600);
pinMode(ledPin, OUTPUT);
void loop() {
if (Serial.available() > 0) {
uint8_t c = Serial.read();
mavlink_message_t msg;
mavlink_status_t status;
if (mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
// check if there is a Heartbeat
if (msg.msgid == MAVLINK_MSG_ID_HEARTBEAT) {
mavlink_heartbeat_t heartbeat;
mavlink_msg_heartbeat_decode(&msg, &heartbeat);
// show informationen Heartbeat-Stream anzeigen
Serial.print("System type: ");
Serial.println(heartbeat.type);
Serial.print("Autopilot type: ");
Serial.println(heartbeat.autopilot);
Serial.print("Base mode: ");
Serial.println(heartbeat.base_mode);
digitalWrite(ledPin, HIGH);
delay(1000);
digitalWrite(ledPin, LOW);
// if there is no message print "no message" and blink LED
else {
Serial.print("No Heartbeat\n");
delay(500);
Does anyone have an idea why it is not working?
Hello!
You need to loop through all available chars and feed them to mavlink_parse_char in a loop, one char at a time.
Right now you are only feeding one char to the parser whenever there is serial data available and then your waiting with delay slowing everything down.
Thanks for the helpful advice, I will change the code and try it.
I modified the code and replaced the if-else statement with a while loop but still I can’t receive the heartbeat.
Also I’m not sure about the baudrate, I tried 57600 and 115200 but both with the same result (115200 is the baudrate in my groundcontrol software).
Any suggestions what I can else try?
void setup() {
Serial.begin(115200);
void loop() {
while (Serial.available() > 0) {
// Check if there is a Heartbeat
// Show information from Heartbeat message
//digitalWrite(ledPin, HIGH);
//delay(1000);
//digitalWrite(ledPin, LOW);
// If there is no message, print "No Heartbeat" and blink LED
if (!Serial.available()) {
//delay(500);
Ok, make sure both ends are using mavlink v2 or v1 and not a mix. Also, as a try, you can print the incoming bytes to check if they make sense. You’re looking for magic bytes (in hex 0xFD or 0xFE). Also see: Serialization · MAVLink Developer Guide
