I was trying to analyze the log data of my flight controller and came across raw acceleration, raw angular velocity (gyroscope), angular velocity FFT. I was wondering if these are plotted with filtered sensor data or raw sensor data. Also from FFT, I see there is vibration around 60-75Hz. Is this vibration large that affects the drone? And, how do I determine if the vibration is due to drone structure resonance or something else?
s there something loose on the frame? Look at the raw accelerometer data—the Z-axis data shouldn’t mask the other axes. Also, the FFT signal should be closer to zero. Maybe the gyro_cutoff is set too low, but I’m not completely sure about that.
another option is bad capasitor …
Hi there
The vibration levels seem to be very high here - so just damping them with software is … not ideal. It will definitely affect your performance.
The peak at 60-70Hz is likely caused by your airframe, but its hard to say what exactly causes this
