I am currently trying to find out how to use the plugin
~/PX4-Autopilot/Tools/sitl_gazebo/src/gazebo_motor_failure_plugin.cpp
in the iris model
I have tried “catkin build -DBUILD_ROS_INTERFACE=ON” in the directory
and also tried adding the motor failure plugin to the iris.sdf model like others did:
<plugin name="motor_failure" filename="libgazebo_motor_failure_plugin.so">
<robotNamespace/>
<ROSMotorNumSubTopic>/motor_failure/motor_number</ROSMotorNumSubTopic>
<MotorFailureNumPubTopic>/gazebo/motor_failure_num</MotorFailureNumPubTopic>
</plugin>
but the ROS topic /motor_failure/motor_number does not generate
Is there a way to solve this?
Thank you,
Kangmin Lee
