Could someone please tell me what the two MISSION_ITEM errors below mean? I am trying to create a /mavros/mission/geofences mavros plugin to read geofence data from an mRo Pixhawk, similar to the plugin /mavros/mission/waypoints. The geofence.cpp file for the plugin mimics the waypoint.cpp file but specifies the misstion_type as 1 for geofences. Why am I not able to use the MISSION_ITEM Mavlink message in both waypoint.cpp and geofence.cpp files? I am using PX4 firmware.
NODES
mavros (mavros/mavros_node)
auto-starting new master
process[master]: started with pid [9780]
ROS_MASTER_URI=http://172.16.0.192:11311
setting /run_id to 23c33030-5d56-11ea-8d2d-001e0636a853
process[rosout-1]: started with pid [9791]
process[mavros-2]: started with pid [9799]
[ INFO] [1583243517.105973670]: FCU URL: /dev/ttyUSB0:921600
[ INFO] [1583243517.115137846]: serial0: device: /dev/ttyUSB0 @ 921600 bps
[ INFO] [1583243517.117529403]: GCS bridge disabled
[ INFO] [1583243517.160821059]: Plugin 3dr_radio loaded
[ INFO] [1583243517.165146121]: Plugin 3dr_radio initialized
[ INFO] [1583243517.165489379]: Plugin actuator_control loaded
[ INFO] [1583243517.175389906]: Plugin actuator_control initialized
[ INFO] [1583243517.197607644]: Plugin adsb loaded
[ INFO] [1583243517.204654145]: Plugin adsb initialized
[ INFO] [1583243517.205385204]: Plugin altitude loaded
[ INFO] [1583243517.208946331]: Plugin altitude initialized
[ INFO] [1583243517.209469760]: Plugin cam_imu_sync loaded
[ INFO] [1583243517.211800732]: Plugin cam_imu_sync initialized
[ INFO] [1583243517.212456373]: Plugin command loaded
[ INFO] [1583243517.231434075]: Plugin command initialized
[ INFO] [1583243517.232009922]: Plugin companion_process_status loaded
[ INFO] [1583243517.238429491]: Plugin companion_process_status initialized
[ INFO] [1583243517.238902294]: Plugin debug_value loaded
[ INFO] [1583243517.250289315]: Plugin debug_value initialized
[ INFO] [1583243517.250430569]: Plugin distance_sensor blacklisted
[ INFO] [1583243517.251141919]: Plugin fake_gps loaded
[ INFO] [1583243517.278373401]: Plugin fake_gps initialized
[ INFO] [1583243517.279066667]: Plugin ftp loaded
[ INFO] [1583243517.299729451]: Plugin ftp initialized
[ INFO] [1583243517.300367967]: Plugin geofences loaded
[ INFO] [1583243517.309713272]: Plugin geofences initialized
[ INFO] [1583243517.310431206]: Plugin global_position loaded
[ INFO] [1583243517.347577924]: Plugin global_position initialized
[ INFO] [1583243517.348127104]: Plugin gps_rtk loaded
[ INFO] [1583243517.353979160]: Plugin gps_rtk initialized
[ INFO] [1583243517.354500423]: Plugin hil loaded
[ INFO] [1583243517.385215987]: Plugin hil initialized
[ INFO] [1583243517.385816918]: Plugin home_position loaded
[ INFO] [1583243517.395525733]: Plugin home_position initialized
[ INFO] [1583243517.396394337]: Plugin imu loaded
[ INFO] [1583243517.417187791]: Plugin imu initialized
[ INFO] [1583243517.417816139]: Plugin landing_target loaded
[ INFO] [1583243517.448175154]: Plugin landing_target initialized
[ INFO] [1583243517.448729292]: Plugin local_position loaded
[ INFO] [1583243517.463721149]: Plugin local_position initialized
[ INFO] [1583243517.464357914]: Plugin log_transfer loaded
[ INFO] [1583243517.472421190]: Plugin log_transfer initialized
[ INFO] [1583243517.473364045]: Plugin manual_control loaded
[ INFO] [1583243517.481800080]: Plugin manual_control initialized
[ INFO] [1583243517.482431011]: Plugin mocap_pose_estimate loaded
[ INFO] [1583243517.491672398]: Plugin mocap_pose_estimate initialized
[ INFO] [1583243517.492206161]: Plugin mount_control loaded
[ INFO] [1583243517.501189041]: Plugin mount_control initialized
[ INFO] [1583243517.501696470]: Plugin obstacle_distance loaded
[ INFO] [1583243517.508606468]: Plugin obstacle_distance initialized
[ INFO] [1583243517.509083188]: Plugin odom loaded
[ INFO] [1583243517.520331289]: Plugin odom initialized
[ INFO] [1583243517.520875510]: Plugin onboard_computer_status loaded
[ INFO] [1583243517.527015198]: Plugin onboard_computer_status initialized
[ INFO] [1583243517.527710131]: Plugin param loaded
[ INFO] [1583243517.536833974]: Plugin param initialized
[ INFO] [1583243517.537391904]: Plugin px4flow loaded
[ INFO] [1583243517.553608790]: Plugin px4flow initialized
[ INFO] [1583243517.553790336]: Plugin rangefinder blacklisted
[ INFO] [1583243517.554517520]: Plugin rc_io loaded
[ INFO] [1583243517.562859094]: Plugin rc_io initialized
[ INFO] [1583243517.563005847]: Plugin safety_area blacklisted
[ INFO] [1583243517.563536651]: Plugin setpoint_accel loaded
[ INFO] [1583243517.572189441]: Plugin setpoint_accel initialized
[ INFO] [1583243517.572998460]: Plugin setpoint_attitude loaded
[ INFO] [1583243517.595504955]: Plugin setpoint_attitude initialized
[ INFO] [1583243517.596126553]: Plugin setpoint_position loaded
[ INFO] [1583243517.628864957]: Plugin setpoint_position initialized
[ INFO] [1583243517.629509306]: Plugin setpoint_raw loaded
[ INFO] [1583243517.651577998]: Plugin setpoint_raw initialized
[ INFO] [1583243517.652215305]: Plugin setpoint_trajectory loaded
[ INFO] [1583243517.666051426]: Plugin setpoint_trajectory initialized
[ INFO] [1583243517.666822361]: Plugin setpoint_velocity loaded
[ INFO] [1583243517.681696757]: Plugin setpoint_velocity initialized
[ INFO] [1583243517.682949579]: Plugin sys_status loaded
[ INFO] [1583243517.711719598]: Plugin sys_status initialized
[ INFO] [1583243517.712432781]: Plugin sys_time loaded
[ INFO] [1583243517.725009081]: TM: Timesync mode: MAVLINK
[ INFO] [1583243517.728404453]: Plugin sys_time initialized
[ INFO] [1583243517.728950258]: Plugin trajectory loaded
[ INFO] [1583243517.745434484]: Plugin trajectory initialized
[ INFO] [1583243517.746031581]: Plugin vfr_hud loaded
[ INFO] [1583243517.747781748]: Plugin vfr_hud initialized
[ INFO] [1583243517.747916251]: Plugin vibration blacklisted
[ INFO] [1583243517.748408763]: Plugin vision_pose_estimate loaded
[ INFO] [1583243517.764685317]: Plugin vision_pose_estimate initialized
[ INFO] [1583243517.765167079]: Plugin vision_speed_estimate loaded
[ INFO] [1583243517.774002623]: Plugin vision_speed_estimate initialized
[ INFO] [1583243517.774628679]: Plugin waypoint loaded
[ERROR] [1583243517.775711705]: MISSION_ITEM (39) <3071041464> routed to different message type (hash: 3274877334)
[ERROR] [1583243517.775854417]: MISSION_ITEM (39) <3071041464> handler dropped because this ID are used for another message type
[ INFO] [1583243517.787021599]: Plugin waypoint initialized
