Integrating OpenCV Object Detection into QGroundControl
Hello, I’m working on a project where I need to engage in object detection via drones. I have the object detection code set up and running. I have done following to achieve that:
  1. Compiled opencv with Gstreamer and QT support from source and did some image processing. I was able to integrate this into QGroundcontrol by building the code as a shared library. (dll)
Now I am running into the following issues:
I want the output frames to be shown inside the QGC window itself, currently processed frames (detection output video stream) are shown using opencv method, imshow(), which results in a separate window.
Is there another approach on how I can use opencv to process frames (e.g from a webcam or RTSP stream) and show it inside the QGC window itself via the VideoManager?
very interesting project. I think the most straightforward way of doing it ( although probably not the most efficient, nor the most elegant one ) is to output the stream from your opencv code to a gstreamer pipeline, to the same UDP address of your machine, loopback, and attempt to open that from QGC.
I think I would first test in terminal a videotestsrc element based pipeline, and get to open it in QGC. From there you can try to do that within your opencv code, and from there it will be straighforward to push your frames instead of videotestsrc element.
For the elegant solution you might pull the string of videoreceiver to link how it is being forwarded to the frontend, etc etc but such approach will be much more time consuming, and if this is just a proof of concept maybe it isn’t worth the effort of going this long route instead.
Good luck!
Neat idea. Did you ever get this working?
Did you find a solution?
Looping back the video to udp output will be quick to test.
But the issue with that is the performance , As the trans coding and repacketization of video packet is involved.
udpsrc ! decodebin ! objectdection ! encode ! rtppackets ! udpsink
You can build the qground control from source code and can add the custom object detection functionality in VideoReceiver Module.
I’m also working on similar projects. Any updates on this?
I am still comparing 2 solutions of integrating opencv with gstreamer on the vehicle end, OR doing it on the QGC end.
Any ideas? :slightly_smiling_face:
QGC can use RTSP directly
The processing was too slow when integrated in QGC. I just built a separate Python app with the yolo object detection code, it output the video as a RTSP which QGC picked up. and displayed. You could execute the Python app through the QGC interface.
