Hello everyone,
I use cube orange with power supply and read the battery status from rp2040-zero.
Have succeeded:read battery status correctly.
Still tried:modify battery status’ property battery_remaining.
Thank you in advance!
void mavlink_send_battery_status(mavlink_battery_status_t battery_status)
uint8_t system_id = 255; // id of computer which is sending the command (ground control software has id of 255)
uint8_t component_id = 2;
mavlink_message_t msg;
uint8_t id=battery_status.id;
uint8_t battery_function=battery_status.battery_function;
uint8_t type=battery_status.type;
int16_t temperature=battery_status.temperature;
uint16_t* voltages=battery_status.voltages;
int16_t current_battery=battery_status.current_battery;
int32_t current_consumed=battery_status.current_consumed;
int32_t energy_consumed=battery_status.energy_consumed;
int8_t battery_remaining=50;
int32_t time_remaining=battery_status.time_remaining;
uint8_t charge_state=battery_status.charge_state;
uint16_t* voltages_ext=battery_status.voltages_ext;
uint8_t mode=battery_status.mode;
uint32_t fault_bitmask=battery_status.fault_bitmask;
//Pack battery message
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
mavlink_msg_battery_status_pack(system_id,component_id,&msg,id,battery_function,type,temperature,voltages,current_battery,current_consumed,energy_consumed,battery_remaining,time_remaining,charge_state,voltages_ext,mode,fault_bitmask);
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg); // Send the message (.write sends as bytes)
Serial1.write(buf, len); //Write data to serial port
