hi All,
is there any way to configure an additional pwm output for wingwing?
i almost have the feeling that i have to adjust this file and compile it again.
Is there an easier way to configure additional PWM outputs?
thanks,
Alex.
hi All,
thanks,
Alex.
I think that’s correct. May I ask what the additional PWM outputs are for?
i’d like to turn “on/off” the fpv gear like cam, osd and video tx by using RC and turn it off after a crash.
In the docs i found a possibility to edit the mixer file without compiling.
I copied wingwing.main.mix and to /fs/microsd/etc/mixers, added the follwing lines and rebooted.
M: 1
S: 3 5 0 20000 -10000 -10000 10000
3 in second mix line stands for Manual Passthrough.
5 in the same line stands for aux1. i mapped an rc channel to aux1 by using qgc
Not sure this is right.
Pwm out 5 has no pwm signal.
i’m wondering if i need an additional mixer as described here
is there some logging about loading the mixer file?
okay found a bit hacky solution. my working mixer file locks now like this:
M: 2
S: 0 0 -6000 -6000 0 -10000 10000
S: 0 1 6500 6500 0 -10000 10000
M: 2
S: 0 1 -6500 -6500 0 -10000 10000
# this will be aux
M: 1
S: 3 5 10000 10000 0 -10000 10000
#throttle
M: 1
S: 0 3 0 20000 -10000 -10000 10000
i don’t know why, but pwm1 - pwm4 is active. pwm5 and pwm6 not. since pwm3 is not used by wing wing, i chose this as the output.
why is pwm5 and pwm6 not active? How do I activate it?
I still haven’t found out how to configure an additional servo output. Isn’t that possible somehow?
