How to add a normal motor to gazebo_sitl
Hi everyone,
I am trying to add a normal motor to a robot I am developing in Gazebo SITL. I have seen the libgazebo_motor_model.so plugin, but I don’t think this works for my purposes since this motor model also produces a thrust and drag moment i.e. it is the motor model for spinning propellers.
I just want a normal motor that can spin a joint. How can I specify something like this and connect it through to the firmware through the airframe ?
Thanks for any input
Best regards,
Ioannis Mandralis
You can have a look how the gimbal of the Typhoon H480 model is made. I believe it uses some sort of motor on a joint:
Thank you very much for your response. However, I think this is for a gimbal joint. I only want to rotate the joint in one axis. Do you know how this could be done ?
Best,
Ioannis
