Which of these two has the better sensor stack? The data sheets are a bit beyond me and they use different sensitivity units. Is either flight controller clearly better?
Clearly the Durandal. Its sensors are also more widely used across other boards.
It’s not. The sensor set in the Durandal didn’t exist when the Naza’s were designed.
