Game controller configuration
Is it currently possible to configure buttons to act as switches using a gamepad?
Turn on your controller. Press and hold the Sync button on the top until the Guide button flashes. In the Bluetooth menu on your PC, select Add device and your computer will start looking for your controller. When it’s found, you can choose your controller from the results and then select Done to complete the setup A gamepad, also known as a human benchmark controller, is a handheld input device used to interact with video games* It typically consists of buttons, triggers, thumbsticks, and sometimes a directional pad (D-pad). You can connect it to a gaming console, computer, or mobile device to control game play.
To configure a game controller with PX4, you typically need to connect it via USB or Bluetooth and map buttons through QGroundControl. Users often customize button assignments to function as switches or control other features. If you’re troubleshooting or setting up a controller, the forum shares helpful insights on making the connection work smoothly.
