Does pixhawk support 4in1 esc
Hello!
I have a pixhawk 2.4.8 flight controller. I wanted to know does this model mentioned above support 4in1 esc?
If yes, which esc has successfully worked best practically?
If no, then which 50Amps esc would be reliable yet light weight?
Kindly revert.
Thanks.
Pixhawk 2.4.8 refers to hardware. The software would be PX4 or ArduPilot. This forum is for PX4. If you’re using MissionPlanner, you would be using ArduPilot (see discuss.ardupilot.org).
A 4in1 ESC usually has 4 connectors to interface to any flight controller. You then usually get the choice between PWM, DShot, or something else as a protocol. PWM and DShot both work with PX4 or ArduPilot.
