Fo_R
1
Hi everyone,
I’ve installed gazebo and PX4 in my windows machine, using wsl. In my Java program, I have added the io.mavsdk:mavsdk:1.3.1 dependency.
When I create an instance of the System class, and try to send commands, nothing happens
I’ve different ports with no success. Any help?
Keep in mind, I’m creating a desktop app, not an android one
Can you share the connection code?
Let me ping @JonasVautherin as he might be able to help with this.
Fo_R
3
void fun Drone(int port) {
// Connect to the drone
System drone = new System("localhost", port);
drone.getAction().takeoff();
dependencies {
// MAVSDK-Java dependencies
implementation("io.mavsdk:mavsdk:1.3.1")
implementation("io.dronefleet.mavlink:mavlink:1.1.11")
// SLF4J binding
implementation("org.slf4j:slf4j-api:2.0.5")
// Logback logging framework
implementation("ch.qos.logback:logback-core:1.4.6")
implementation("ch.qos.logback:logback-classic:1.4.6")
Can you share more of the code where you actually call Drone and with what port argument?
And are you aware of this example?
I have included all dependencies which you have mentioned above still, I’m getting this error:
import org.slf4j.Logger
The import org.slf4j.Logger cannot be resolved.
import org.slf4j.LoggerFactory;
The import org.slf4j.LoggerFactory cannot be resolved.
how to build this project as maven or java.I made maven project added dependencies in POM.xml file.
Thanks in advance.
