Connecting Database with QGC
Is there any way to connect an external database with QGC?
Yes. Short answer for a short question.
Can you give some context. How are we supposed to know what you mean? What is the actual problem you’re trying to solve?
Hey Julian! Thankyou for responding. We have decided to include object detection feature into the drone using yolo and need to display the thumbnails and latitude, longitude data of the detected objects in QGC.
The images will be retrieved from the local storage so no need of a database. Can you tell me which files should I change to include this feature?
Hello, did you ever find a solution to this problem? We are attempting something similar.
Hii if there is any possible to connect the data base for save the user name and password and that I will connect and that I will retrieve also it’s possible how will idi that
