@acfloria Thanks for ur suggestion and ur time
when the example provided in the doc didn’t work, I also came to the same conclusion
I copied the last line and tried adding it to the stream_list array as follows ( Check the last line )
static const StreamListItem streams_list[] = {
StreamListItem(&MavlinkStreamHeartbeat::new_instance, &MavlinkStreamHeartbeat::get_name_static, &MavlinkStreamHeartbeat::get_id_static),
StreamListItem(&MavlinkStreamStatustext::new_instance, &MavlinkStreamStatustext::get_name_static, &MavlinkStreamStatustext::get_id_static),
StreamListItem(&MavlinkStreamCommandLong::new_instance, &MavlinkStreamCommandLong::get_name_static, &MavlinkStreamCommandLong::get_id_static),
StreamListItem(&MavlinkStreamSysStatus::new_instance, &MavlinkStreamSysStatus::get_name_static, &MavlinkStreamSysStatus::get_id_static),
StreamListItem(&MavlinkStreamHighresIMU::new_instance, &MavlinkStreamHighresIMU::get_name_static, &MavlinkStreamHighresIMU::get_id_static),
StreamListItem(&MavlinkStreamScaledIMU::new_instance, &MavlinkStreamScaledIMU::get_name_static, &MavlinkStreamScaledIMU::get_id_static),
StreamListItem(&MavlinkStreamScaledIMU2::new_instance, &MavlinkStreamScaledIMU2::get_name_static, &MavlinkStreamScaledIMU2::get_id_static),
StreamListItem(&MavlinkStreamScaledIMU3::new_instance, &MavlinkStreamScaledIMU3::get_name_static, &MavlinkStreamScaledIMU3::get_id_static),
StreamListItem(&MavlinkStreamAttitude::new_instance, &MavlinkStreamAttitude::get_name_static, &MavlinkStreamAttitude::get_id_static),
StreamListItem(&MavlinkStreamAttitudeQuaternion::new_instance, &MavlinkStreamAttitudeQuaternion::get_name_static, &MavlinkStreamAttitudeQuaternion::get_id_static),
StreamListItem(&MavlinkStreamVFRHUD::new_instance, &MavlinkStreamVFRHUD::get_name_static, &MavlinkStreamVFRHUD::get_id_static),
StreamListItem(&MavlinkStreamGPSRawInt::new_instance, &MavlinkStreamGPSRawInt::get_name_static, &MavlinkStreamGPSRawInt::get_id_static),
StreamListItem(&MavlinkStreamGPS2Raw::new_instance, &MavlinkStreamGPS2Raw::get_name_static, &MavlinkStreamGPS2Raw::get_id_static),
StreamListItem(&MavlinkStreamSystemTime::new_instance, &MavlinkStreamSystemTime::get_name_static, &MavlinkStreamSystemTime::get_id_static),
StreamListItem(&MavlinkStreamTimesync::new_instance, &MavlinkStreamTimesync::get_name_static, &MavlinkStreamTimesync::get_id_static),
StreamListItem(&MavlinkStreamGlobalPositionInt::new_instance, &MavlinkStreamGlobalPositionInt::get_name_static, &MavlinkStreamGlobalPositionInt::get_id_static),
StreamListItem(&MavlinkStreamLocalPositionNED::new_instance, &MavlinkStreamLocalPositionNED::get_name_static, &MavlinkStreamLocalPositionNED::get_id_static),
StreamListItem(&MavlinkStreamOdometry::new_instance, &MavlinkStreamOdometry::get_name_static, &MavlinkStreamOdometry::get_id_static),
StreamListItem(&MavlinkStreamEstimatorStatus::new_instance, &MavlinkStreamEstimatorStatus::get_name_static, &MavlinkStreamEstimatorStatus::get_id_static),
StreamListItem(&MavlinkStreamAttPosMocap::new_instance, &MavlinkStreamAttPosMocap::get_name_static, &MavlinkStreamAttPosMocap::get_id_static),
StreamListItem(&MavlinkStreamHomePosition::new_instance, &MavlinkStreamHomePosition::get_name_static, &MavlinkStreamHomePosition::get_id_static),
StreamListItem(&MavlinkStreamServoOutputRaw<0>::new_instance, &MavlinkStreamServoOutputRaw<0>::get_name_static, &MavlinkStreamServoOutputRaw<0>::get_id_static),
StreamListItem(&MavlinkStreamServoOutputRaw<1>::new_instance, &MavlinkStreamServoOutputRaw<1>::get_name_static, &MavlinkStreamServoOutputRaw<1>::get_id_static),
StreamListItem(&MavlinkStreamServoOutputRaw<2>::new_instance, &MavlinkStreamServoOutputRaw<2>::get_name_static, &MavlinkStreamServoOutputRaw<2>::get_id_static),
StreamListItem(&MavlinkStreamServoOutputRaw<3>::new_instance, &MavlinkStreamServoOutputRaw<3>::get_name_static, &MavlinkStreamServoOutputRaw<3>::get_id_static),
StreamListItem(&MavlinkStreamHILActuatorControls::new_instance, &MavlinkStreamHILActuatorControls::get_name_static, &MavlinkStreamHILActuatorControls::get_id_static),
StreamListItem(&MavlinkStreamPositionTargetGlobalInt::new_instance, &MavlinkStreamPositionTargetGlobalInt::get_name_static, &MavlinkStreamPositionTargetGlobalInt::get_id_static),
StreamListItem(&MavlinkStreamLocalPositionSetpoint::new_instance, &MavlinkStreamLocalPositionSetpoint::get_name_static, &MavlinkStreamLocalPositionSetpoint::get_id_static),
StreamListItem(&MavlinkStreamAttitudeTarget::new_instance, &MavlinkStreamAttitudeTarget::get_name_static, &MavlinkStreamAttitudeTarget::get_id_static),
StreamListItem(&MavlinkStreamRCChannels::new_instance, &MavlinkStreamRCChannels::get_name_static, &MavlinkStreamRCChannels::get_id_static),
StreamListItem(&MavlinkStreamManualControl::new_instance, &MavlinkStreamManualControl::get_name_static, &MavlinkStreamManualControl::get_id_static),
StreamListItem(&MavlinkStreamTrajectoryRepresentationWaypoints::new_instance, &MavlinkStreamTrajectoryRepresentationWaypoints::get_name_static, &MavlinkStreamTrajectoryRepresentationWaypoints::get_id_static),
StreamListItem(&MavlinkStreamOpticalFlowRad::new_instance, &MavlinkStreamOpticalFlowRad::get_name_static, &MavlinkStreamOpticalFlowRad::get_id_static),
StreamListItem(&MavlinkStreamActuatorControlTarget<0>::new_instance, &MavlinkStreamActuatorControlTarget<0>::get_name_static, &MavlinkStreamActuatorControlTarget<0>::get_id_static),
StreamListItem(&MavlinkStreamActuatorControlTarget<1>::new_instance, &MavlinkStreamActuatorControlTarget<1>::get_name_static, &MavlinkStreamActuatorControlTarget<1>::get_id_static),
StreamListItem(&MavlinkStreamActuatorControlTarget<2>::new_instance, &MavlinkStreamActuatorControlTarget<2>::get_name_static, &MavlinkStreamActuatorControlTarget<2>::get_id_static),
StreamListItem(&MavlinkStreamActuatorControlTarget<3>::new_instance, &MavlinkStreamActuatorControlTarget<3>::get_name_static, &MavlinkStreamActuatorControlTarget<3>::get_id_static),
StreamListItem(&MavlinkStreamNamedValueFloat::new_instance, &MavlinkStreamNamedValueFloat::get_name_static, &MavlinkStreamNamedValueFloat::get_id_static),
StreamListItem(&MavlinkStreamDebug::new_instance, &MavlinkStreamDebug::get_name_static, &MavlinkStreamDebug::get_id_static),
StreamListItem(&MavlinkStreamDebugVect::new_instance, &MavlinkStreamDebugVect::get_name_static, &MavlinkStreamDebugVect::get_id_static),
StreamListItem(&MavlinkStreamDebugFloatArray::new_instance, &MavlinkStreamDebugFloatArray::get_name_static, &MavlinkStreamDebugFloatArray::get_id_static),
StreamListItem(&MavlinkStreamNavControllerOutput::new_instance, &MavlinkStreamNavControllerOutput::get_name_static, &MavlinkStreamNavControllerOutput::get_id_static),
StreamListItem(&MavlinkStreamCameraCapture::new_instance, &MavlinkStreamCameraCapture::get_name_static, &MavlinkStreamCameraCapture::get_id_static),
StreamListItem(&MavlinkStreamCameraTrigger::new_instance, &MavlinkStreamCameraTrigger::get_name_static, &MavlinkStreamCameraTrigger::get_id_static),
StreamListItem(&MavlinkStreamCameraImageCaptured::new_instance, &MavlinkStreamCameraImageCaptured::get_name_static, &MavlinkStreamCameraImageCaptured::get_id_static),
StreamListItem(&MavlinkStreamDistanceSensor::new_instance, &MavlinkStreamDistanceSensor::get_name_static, &MavlinkStreamDistanceSensor::get_id_static),
StreamListItem(&MavlinkStreamExtendedSysState::new_instance, &MavlinkStreamExtendedSysState::get_name_static, &MavlinkStreamExtendedSysState::get_id_static),
StreamListItem(&MavlinkStreamAltitude::new_instance, &MavlinkStreamAltitude::get_name_static, &MavlinkStreamAltitude::get_id_static),
StreamListItem(&MavlinkStreamADSBVehicle::new_instance, &MavlinkStreamADSBVehicle::get_name_static, &MavlinkStreamADSBVehicle::get_id_static),
StreamListItem(&MavlinkStreamUTMGlobalPosition::new_instance, &MavlinkStreamUTMGlobalPosition::get_name_static, &MavlinkStreamUTMGlobalPosition::get_id_static),
StreamListItem(&MavlinkStreamCollision::new_instance, &MavlinkStreamCollision::get_name_static, &MavlinkStreamCollision::get_id_static),
StreamListItem(&MavlinkStreamWind::new_instance, &MavlinkStreamWind::get_name_static, &MavlinkStreamWind::get_id_static),
StreamListItem(&MavlinkStreamMountOrientation::new_instance, &MavlinkStreamMountOrientation::get_name_static, &MavlinkStreamMountOrientation::get_id_static),
StreamListItem(&MavlinkStreamHighLatency2::new_instance, &MavlinkStreamHighLatency2::get_name_static, &MavlinkStreamHighLatency2::get_id_static),
StreamListItem(&MavlinkStreamGroundTruth::new_instance, &MavlinkStreamGroundTruth::get_name_static, &MavlinkStreamGroundTruth::get_id_static),
StreamListItem(&MavlinkStreamPing::new_instance, &MavlinkStreamPing::get_name_static, &MavlinkStreamPing::get_id_static),
StreamListItem(&MavlinkStreamOrbitStatus::new_instance, &MavlinkStreamOrbitStatus::get_name_static, &MavlinkStreamOrbitStatus::get_id_static),
StreamListItem(&MavlinkStreamPR01::new_instance, &MavlinkStreamPR01::get_name_static, &MavlinkStreamPR01::get_id_static)
when i do this i get the error
error: no matching function for call to 'StreamListItem::StreamListItem(MavlinkStream* (*)(Mavlink*), const char* (*)(), uint16_t (MavlinkStreamPR01::*)())'
from what i understand , this error ,the compiler is trying to say it isnt able to find a fuction prototype/defn (the streamlistitem constructor) with the given signature (the one mentioned in the error and typed out in the array)
please correct me if i am wrong
