I could not use the cmake for the examples so I manually created an app using the takeoff and land example. I verified that my pc wifi is connected to the drone (3DR solo using OpenSolo). When I start the app using command line option udp://10.1.1.1 I get as far as
auto system = mavsdk.first_autopilot(3.0);
and it fails then goes to
if (!system) {
std::cerr << "Timed out waiting for system\n";
and exits;
my drone is uses mavlink V1. Does MAVSDK still support V1?
I can still arm, takeoff and land from my old V1 header based code but it was suggested that I try MAVSDK.
