Hi, i can arm the drone when is connected to pc put when i disconnect the usb cable the drone wont arm. The led is blue when i try to arm blinks red?
same issue here. Did you find a solution to your problem? I tried everything from re-flashing and diabling safety checks but still the drone is intact on the floor
