Hi all,
I am running PX4 1.11.3 on an MRO control zero and want to use the BMP388 baro. When I send a Mavlink command in in QGC such as “bmp388 status” it reports an error command not found. When I run this command on a cube black running the same version of px4 I don’t get any errors and a status is printed. Do I have to add code for the control zero target to use the BMP388?
Thanks
