I flew a mission on my standard plane. It figured out that the autopilot was cheating a little bit, so it flew around the waypoints. Is it possible to set up a higher accuracy?
Hi @Steven_Teacher ,
What do you exactly mean by “higher accuracy” ? Do you want to go over the waypoints? The waypoint switching distance is based on the L1 distance which is calculated from:
