Hi there. I have problem with transition and cannot find solution for this.
In transition, after going horizontal i cannot start to use elevons to control. There are some movements on elevons up and down but it does not react for elevons and throttle stick movements.
I is flying very well as copter, also starting transition very smoothly, but still i cannot fly it in plane mode. I attached my logs and screen of parameters.
I dont have pitot tube and did most of things like in manual. What Iām doing wrong?
At the moment the VTOL tailsitter code requires an airspeed sensor to check that transition succeeded, but with a small code change it could be updated to work without.
