Hello guys!
I am testing vision position estimate in LPE mode.
I am using MSF framework to fuse vision and imu data.
I can get pretty good position estimation information from VISION_POSITION_ESTIMATE
message(not using vision for heading, but it seems that is not enough, because when I switch to POSCTL
mode, QuadCopter keep fly around in a circle. It looks like this:
And this is my flying log file:http://logs.uaventure.com/view/QcABiUm82uMMLwzAU8SjBX
As mhkabir suggested, I should use vision for heading, I know by set ATT_EXT_HDG_M
can enable this function. But I don’t really know how to mess with MSF settings. This is my MSF settings:
data_playback: false
core/core_fixed_bias: false
#########IMU PARAMETERS#######
####### pixhawk - MPU6050
core/core_noise_acc: 0.013
core/core_noise_accbias: 0.000108
core/core_noise_gyr: 0.00065
core/core_noise_gyrbias: 0.00000212
pose_sensor/pose_fixed_scale: false
pose_sensor/pose_noise_scale: 0.0
pose_sensor/pose_noise_p_wv: 0.0
pose_sensor/pose_noise_q_wv: 0.0
pose_sensor/pose_noise_q_ic: 0.0
pose_sensor/pose_noise_p_ic: 0.0
pose_sensor/pose_delay: 0.02
pose_sensor/pose_noise_meas_p: 0.005
pose_sensor/pose_noise_meas_q: 0.02
pose_sensor/pose_initial_scale: 5.60
# q_ic is the quaternion representing the rotation of the camera in IMU frame. Unit quaternion here as we rotate the coordinate frames in SVO parameters.
pose_sensor/init/q_ic/w: 1.0
pose_sensor/init/q_ic/x: 0.0
pose_sensor/init/q_ic/y: 0.0
pose_sensor/init/q_ic/z: 0.0
# p_ic is the translation between the IMU and the camera in meters.
pose_sensor/init/p_ic/x: 0.1
pose_sensor/init/p_ic/y: 0.0
pose_sensor/init/p_ic/z: 0.065
pose_sensor/pose_absolute_measurements: true
pose_sensor/pose_use_fixed_covariance: true
pose_sensor/pose_measurement_world_sensor: false # we do not publish the world in camera frame as set in SVO parameters.
pose_sensor/pose_fixed_p_ic: true
pose_sensor/pose_fixed_q_ic: true
pose_sensor/pose_fixed_p_wv: false
pose_sensor/pose_fixed_q_wv: false
I have a downward-facing camera with image top the same as pixhawk forward direction. So I think keep pose_sensor/init/q_ic/w:1 x:0 x:0 y:0 z:0
should be fine. But that can not make ATTITUDE.roll/pitch/yaw
and VISION_POSITION_ESTIMATE.roll/pitch/yaw
the same.
Could anyone help? Thanks!
