Hi guys,
After days of testing and searching, I couldn’t find the solution of my problem. Basically I’m trying to write a VERY simple takeoff script to get familiar with MAVROS and other concepts.
My problem is that everytime I try switch the flight mode to OFFBOARD I got this message: “FCU: Failsafe enabled: no RC and no offboard”.
I’ve read the documentation and follow this tutorial: https://dev.px4.io/en/ros/mavros_offboard.html
Few things that I did. and you should know.
- I’m publishing points (100) before switching to OFFBOARD mode.
- I’ve changed the rate from 10 to 20 (even tried with 30)
- I tried to publish both local_position/local and global_position/global.
- QGroundControl is open, otherwise I would have a “datalink missing” error.
- Also the header.stamp is corrected set.
- tried to switch to OFFBOARD via QGroundcontrol, didn’t work
- Tried to switch via command line, didn’t work (make sens if you have to publish a point within 0.5 sec)
The code flow: change the rate -> publish 100 points -> change mode to offboard -> arm -> publish again.
It get the failsafe error and RTL mode is being enabled.
Thanks for reading.
