I am using the Pixhawk mini with S-Bus Rx, Taranis Tx on a quad copter. But I cannot get the AUX1 or AUX2 to Pass thru so i can use a servo. On QC Ground Control I can see the servos are responding but the actual servos are not moving (Yes, I have the UBEC connected to pin 8).
Thank you. Yes I did see the docs, but didn’t realized that TriCopter does not support AUX servo use (Assumption is mother of all screw-ups!). I was planning to place a gripper servo that is why I needed Aux pass through.
