Got it ! Thanks much @Serge : )
I am wiring the same circuit on your picture.Does it work on your drone?
TOM
Hello
On the photography, the splitter was used for AUX port. But you can use the first Splitter for the ESC.
On The Pixhawk4 , two ports are aviable the first for connect the ESC and the second for AUX (default configuration).
https://docs.px4.io/v1.9.0/en/assembly/quick_start_pixhawk4.html
Serge
All, I am waiting for the common package avalanche from Webshops, preparing in advance to wire up my Hexacopter with Pixhawk-4 and the power module as described in this topic. It would have the advantage of monitoring all current drained from my main battery if I also hookup my ESCĀ“s to this board.
The Documentation on the power module is somewhat limited: it states it can deliver upto 120A. Not sure if that is absolute MAX, or if there is like a peak value not to cross, or if it is even able to cut current when 120A is to be exceeded.
@lloydrayner : I see you hooked up 30A ESCĀ“s, in my case times 6 = 180A. Did you do any stress test on maximum current, and what curren thave you been able to pull out of the Power Module whilst not smoking it ?
grtz
John
All,
I got a decent and clear answer from Holybro on the max. current when distribution to ESC/Motors is done through the PM07 module:
āIf the continuous working current for your motor is 30A then you should not choose PM07 but a PDB capable of more than 250A instead.
For the hexacopter, pm07 only allows the continuous working current of each motor to be less than 20A. The boost current of pm07 may reach 180A, but it can only withstand for a short time, pm07 will generate a lot of heat which results in a decrease in reliability.ā
grtz
John
Hey,
Iām in the same situation as the original poster. The kit I got from holybro is said to be āsolder-lessā, so the wires that comes out of the ESC have a little connector (the square one of this photo):
Do I really need to cut this connector and solder the white cable to M1, M2, M3, and M4?
Or can I plug them directly on the pixhawk 4 (and use only the PM board for alimentation?)
Or maybe I can use the angled connector on the bottom picture?
Thanks,
Rev
Hi, Sir.
I am a little bit confused by all the online pics. Is that ok either to connect the singal ground wire or not, or doesnāt matter at all?
Hello
Iām trying to build an Airboat with differential thrust
I have:
Pixhawk 4 with the power module
GPS
R12DS Radioink receiver
AT10 Radiolink transmitter
2 80A ECS
2 brushless motors 620KV
I have installed AurduRover/boat
I have connected the ESCs to M1 and M2 in the power module,
however, the M2 (motor 2) is not working
anyone out there that could help me out
Thanks
@Rev:
I am in the same situation with the same question. Do you have any advice based on what worked for you?
Please provide some details if possible,
Thanks
Bindu
Hey there. I had to plug the wire directly on the power board from the esc (the small rectangle connector). Iāll be able to grab some picture tomorrow if you want
That would be great, will help me to see how it is done, Thanks in advance,
Bindu
Hi Sir, I am using this PM02 for my F450 Frame with Pixhawk 4. I already soldered my 4 ESCs Back+Red big cables into the PCB bottom board of the frame. Besides, my ESCs have another twisted thin white+black cable which means signal wires(I guess). Because the PM02 doesnāt have a little hole to solder the white signal like the PM07(showed in some pictures above), I just connected my 4 ESC signal wires to the slitter, then connect to the I/O PWM OUT(on the Pixhawk 4) through that 10-to-10 pin wires( as you described āclosed to M4)ā. So, I am wondering if it is a correct connection(no other step or connection needed) that the power from the battery could make 4 motors rotate? The reason I asked this is that when I do some setup on Ardupilot, I got stuck at the āESC calibrationā step, which prevented me from making all 4 motors rotate. When I plugged the battery in, all motors are beeping which means the PCB should work. That makes me think the above connection might be wrong or lack of connection. If you know what could be a reason and how to solve it, please help. I would appreciate that a lot. Thank you.
Hi sir! I have questions to ask. First i have a 4-in-1 ESC ( Dshot1200- mamba stack as pictured). What can i do to connect it to a Pixhawk 4. How can i powered the ESC because im using a 6s battery to power up my motors. Is that necessary to power up both esc and pixhawk with 2 dedicated LIPOs or i can sold my ESC to 1 of the output power of the Power Management Board. Is that enough to power all four motors of mine. The second is that is there any caution should i take when config it through mission planer app?. Or Pixhawk will recognize ESC as normal?
Hi did the spliiter work for the ESCsā signal wires?
Thank you in advance
