Hi developers,
I am running simulation using Gazebo, and I use MAVROS to interface between ROS and gazebo to do some offboard mission. I would like to ask if there is a way/plugin/message that I can use to acquire the actual position of the simulated IRIS? I can get EKF estimated position from the /mavros/local_position/pose topic, but would want to have the actual position of the drone in the simulated environment, to do some comparison.
Thanks!
Best Regards
