Hi everyone,
EDIT : Please ignore this post, I’m an idiot. LPOS is based on a coordinate system that is set where the aircraft started (turned on or armed, I don’t know, but in this situation it doesn’t matter as they are the same), as explained a while ago in this answer to another of my questions. All the graphs make perfect sense now, and nothing is wrong.
I have been going over some flight logs, and found something very confusing… It looks like the LPOS_X and LPOS_Y are switch around. Is my understanding incorrect that LPOS_VX is forward velocity, and LPOS_VY is velocity to the right?
I have attached velocity and position graphs of a flight below, made by px4tools. The aircraft suffered from some serious dutch roll, and ended in a crash. To give you and an idea what the flight looked like, I also attached a graph of roll attitude. You can see it oscillates about the roll axis, getting worse as time goes on.
Now what confuses me, is that the LPOS_VX graph oscillates in time with the roll attitude, not LPOS_VY. Furthermore, it crosses over the x-axis of the graph, and I’m pretty sure my fixed wing never managed a negative forward velocity.
If you look at the position graph, my plane travels -40m forwards, and 116m sideways. I don’t recall that much wind, and if there was, I was flying into the wind, not across it.
I know it’s not an IMU rotation thing in the parameters, because ATT_Roll, ATT_Pitch etc. are all correct.
Z is also confusing because it says I reached a maximum altitude of 2m, but I know I flew at least 4m high. That’s a question for another time, though.
<img src=“/uploads/default/original/1X/7d8682de406da923e5ac6bce8b2a3bda54e73bbb.png” width="690"height=“230”>
