Hi! Im wondering which is the correct way to load 2 mixers in SITL mode.
For SITL we have init scripts located at “posix-configs/SITL/init/ekf2”
They are loading mixers with “mixer load /dev/pwm_output0 ROMFS/sitl/mixers/somefile.mix” command.
At the same time they have “param set SYS_AUTOSTART NUMBER”
Where NUMBER points to startup script in “ROMFS/px4fmu_common/init.d” which uses “set MIXER some_name_without_mix_ext” and “set MIXER_AUX some_name_without_mix_ext” pointing to files in “ROMFS/px4fmu_common/mixers”.
Does it affects SITL in any way? It looks like mixers defined with “set MIXER” and “set MIXER_AUX” has no effect when doing SITL.
At the same time there is no way to load 2 mixers for SITL as only “mixer load /dev/pwm_output0 …” is working and “mixer load /dev/pwm_output1 …” produces an error:
ERROR [mixer] can’t open /dev/pwm_output1
ERROR [mixer] failed to load mixer
I gave it a try and it seems kind of working when number of control channels is not big enough. For example I was able to add one more layer of 4 motors to quad rotor model having already 4 motors. Doing mixer append made them kind of working together. Each layer was controlled independently I believe but together they was able to make model to fly.
Then I tried to do the same with standard_vtol_sitl. I added one more layer of 4 motors to it. Now it has 11 control channels in total. I used mixer append to add one standard quad rotor controller for new layer of motors (R: 4x 10000 10000 10000 0). And I see those motors not rotating at all.
Maybe there are some restrictions on total number of control channels available in SITL?
I even tried to change mixer file adding this line (R: 4x 10000 10000 10000 0) at the end just to not do any mixer append and load a single mixer file. The result is the same. Those new motors not rotating at all.
The output as follows. Nothing really suspicious for me. Except for couple of warnings, but those are always there and not prohibit the model from working in configuration with number of channels less than 8.
[Msg] Waiting for master.
[Msg] Publicized address: 192.168.1.85
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [front_right_top_joint] found for channel[0] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [back_left_top_joint] found for channel[1] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [front_left_top_joint] found for channel[2] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [back_right_top_joint] found for channel[3] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [pusher_joint] found for channel[4] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [front_right_bottom_joint] found for channel[8] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [back_left_bottom_joint] found for channel[9] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [front_left_bottom_joint] found for channel[10] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [back_right_bottom_joint] found for channel[11] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [left_wing_and_elevon_joint] found for channel[5] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [right_wing_and_elevon_joint] found for channel[6] joint control active for this channel.
[Dbg] [gazebo_mavlink_interface.cpp:160] joint [elevator_joint] found for channel[7] joint control active for this channel.
SITL COMMAND: /Users/ali/Documents/Firmware/build/posix_sitl_default/px4 /Users/ali/Documents/Firmware /Users/ali/Documents/Firmware/posix-configs/SITL/init/ekf2/universal
data path: /Users/ali/Documents/Firmware
commands file: /Users/ali/Documents/Firmware/posix-configs/SITL/init/ekf2/universal
INFO [simulator] Got initial simulation data, running sim…
INFO [pwm_out_sim] MODE_8PWM
INFO [tone_alarm] startup
WARN [vtol_att_control] failed setting min values
INFO [commander] Takeoff detected
WARN [vtol_att_control] failed setting max values
INFO [mavlink] mode: Normal, data rate: 2000000 B/s on udp port 14556 remote port 14550
INFO [mavlink] mode: Onboard, data rate: 2000000 B/s on udp port 14557 remote port 14540
INFO [mavlink] MAVLink only on localhost (set param MAV_BROADCAST = 1 to enable network)
pxh> INFO [logger] Start file log
INFO [logger] Opened log file: rootfs/fs/microsd/log/2018-03-10/18_55_03.ulg
INFO [commander] Landing detected
INFO [lib__ecl] EKF aligned, (pressure height, IMU buf: 22, OBS buf: 14)
INFO [lib__ecl] EKF GPS checks passed (WGS-84 origin set)
INFO [commander] home alt: 488.12
INFO [lib__ecl] EKF commencing GPS fusion
INFO [commander] home: 47.3977418, 8.5455934, 488.04
INFO [tone_alarm] home_set
Thanks @Bart for your point. I found in sources that there are different modes like MODE_8PWM, MODE_14PWM, MODE_16PWM etc. So It seems like MODE_14PWM should play nice for me. But I can’t find command to set this kind of mode. Could you pls point to particular documentation page where that described? Or at least provide with appropriate command to add to my init script?
