Hello everyone. Tell me, what is the difference between Kakute H7 and H743? I’m collecting VTOL and I don’t know which is better? Does BetaFlight support H743?
What do you mean with H743? Do you have a link?
Ah, thanks!
On first glance it looks like you get a lot more pins and connectors on the H743, however, it’s slightly bigger. For VTOL probably a good choice.
Regarding betaflight, I don’t know. But I’m mentioning @Vincentpoont2, he’ll know.
Thank you for the answer, you helped me a lot!
@lordunknown52 The Kakute H743-Wing designed for fixed wing user and come with a Power board with 3 On-board BEC output 5V, 6V/8V and 9V/12V. It also has 1x CAN Bus, Dual Camera Inputs switch, Camera/VTX power switch, etc.
It has a header pin design so you can easily plug dupont connector into the Motor signal.
The H743 Wing is not supported in Betaflight. While the Kakute H7 is.
**Firmware Support for the H743 wing **
Ardupilot Target: KAKUTEH7-Wing(Ardupilot 4.4 or newer)
INAV Target: KAKUTEH7Wing (INAV 6.1.1 or newer)
Good afternoon. Thank you so much for your advice and help!
