When I execute the “make px4fmu-v2_default” command to make px4 v1.6.2 code, It remind me this error.
Who has seen this problem?
– Nuttx build for px4fmu-v2 on m4 hardware, using nsh with ROMFS on px4fmu_common
– Build Type: MinSizeRel
File “Tools/tag_to_version.py”, line 19, in
minor = res[1]
IndexError: list index out of range
– PX4 VERSION: 3284b7d
– CONFIG: nuttx-px4fmu-v2-default
– Found assembler: /home/yst/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-gcc
– Found PythonInterp: /usr/bin/python (found version “2.7.12”)
– Found PY_jinja2: /usr/local/lib/python2.7/dist-packages/jinja2
– C compiler: arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204]
– C++ compiler: arm-none-eabi-g++ (GNU Tools for Arm Embedded Processors 7-2017-q4-major) 7.2.1 20170904 (release) [ARM/embedded-7-branch revision 255204]
– Adding ROMFS on px4fmu-v2
– Nuttx build for px4fmu-v2 on m3 hardware, using nsh
– Configuring done
– Generating done
– Build files have been written to: /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default
[73/566] Building NuttX for px4io-v2 with nsh
FAILED: cd /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4io-v2 && /bin/rm -rf /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4io-v2/NuttX/nuttx/nuttx-export && /usr/bin/make --quiet --no-print-directory -C /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4io-v2/NuttX/nuttx -r CONFIG_ARCH_BOARD=px4io-v2 export >nuttx_build.log && cmake -E touch /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4io-v2/nuttx_export.stamp
stdio/lib_sscanf.c: In function ‘vsscanf’:
stdio/lib_sscanf.c:419:28: error: this statement may fall through [-Werror=implicit-fallthrough=]
sign = true;
stdio/lib_sscanf.c:420:21: note: here
case ‘u’:
cc1: all warnings being treated as errors
make[2]: *** [bin/lib_sscanf.o] Error 1
make[1]: *** [libc/libc.a] Error 2
[73/566] Building NuttX for px4fmu-v2 with nsh
FAILED: cd /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4fmu-v2 && /bin/rm -rf /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4fmu-v2/NuttX/nuttx/nuttx-export && /usr/bin/make --quiet --no-print-directory -C /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4fmu-v2/NuttX/nuttx -r CONFIG_ARCH_BOARD=px4fmu-v2 export >nuttx_build.log && cmake -E touch /home/yst/px4_code/px4_0/xyi_px4/build_px4fmu-v2_default/px4fmu-v2/nuttx_export.stamp
sign = true;
case ‘u’:
Makefile:164: recipe for target ‘px4fmu-v2_default’ failed
make: *** [px4fmu-v2_default] Error 1
