External BEC 5V with 3A is need for pixhawk 4 PMB? I am using BLheli 30 A build-in 5V 2 A ESC in my quadcopter. my connection from pixhawk 4 to PMB are FMU PWM out to I/O PWM in. kindly give your suggestion …Thanks.
The 5V BEC is only needed if you need to power a servo motor or some other device that needs 5V. If you are just using brushless motors with ESCs that have a 5V BEC built in then you don’t need to provide 5V to the pmb. Let me know if you have further questions.
https://www.youtube.com/watch?v=moegKh8gHdI,
I have posted my problem in youtube… need your valuable commands Plz.
What airframe did you choose from qgc? quad x? Moreover did you disable the IO using the SYS_USE_IO parameter on qgc? If it is enabled the motors will be mapped to the IO pins and not fmu.
Quad-X , still i am having motor beep issue. need some help
By default PX4 outputs the motor pwms on the IO port. Either try to connect to the IO port or check the SYS_USE_IO parameter. If you want the pwms from the FMU port then this parameter has to be disabled.
Hi vasanth kumar
Conect i/out pwm out to fmu_ pwm in
Your motor will start working properly
