Hey folks,I’ve been running a bunch of bench tests on heavy-lift multirotor motors lately, and I’ve run into some confusing log trends that don’t fully match my lab data. Just wanna bounce this off everyone who flies custom frames with PX4.A few weird patterns I’ve noticed:
Even after full ESC calibration, my flight logs still show small but steady RPM gaps between four motors during long mapping hovers. Is this mostly down to tiny rotor balance differences, or winding resistance inconsistencies I’m missing?
When running spray rigs at near-max throttle for hours straight, logs show each motor heats up at totally different rates. Does uneven heat throw off PX4’s auto-thrust balancing enough to trigger false EKF vibration alerts?
I’ve tried mixing two slightly different KV motors as a temporary fix once, and waypoint drift got noticeably worse. Can PX4’s built-in motor compensation really smooth out that mismatch, or is swapping matched motors the only real fix?
Long-term wear seems to slowly loosen rotor magnets inside some motors. I’ve watched vibration numbers creep up flight after flight until saturation warnings pop up. Has anyone else caught this early just from log data before physical failure?
I’m trying to put together a simple checklist to spot motor hardware wear straight from flight review files. If you’ve got any similar weird log observations or quick fixes you’ve found, I’d love to hear your real flight experiences!
