Demand 10km + frequency jump video transmission, I found ARLink-C201-D from artosyn, but the interface hopes to find a network interface.What do you recommend ?
L x W x H = 36mm x 30mm x 3mm
Work frequency band
2.4/5.8G dual-frequency frequency
SDK default: 2400MHz~2483.5MHz
Support for 2.3GHz ~ 2.7GHz
SDK Default: 5725MHz~5850MHz
Support for 4.9GHz ~ 5.9GHz
modulation mode
BPSK, QPSK, 16QAM, and 64QAM autoadaptation
channel bandwidth
10MHz/ 20MHz
rccontroller
1.25MHz
transmission distance
10 KM (open field without interference)
transmission speed
down
The Maximum 27Mbps dynamic code rate
up
BPSK , 1/2: 50 Kbps,
QPSK , 2/3: 148 Kbps
time delay
Data transfer delay
30 ms
Emission power (postage stamp
Hole RF Interface)
SKY
2.4G =22dBm
5.8G =19dbm is configurable
GROUND
2.4G =24dBm
5.8G =20dbm is configurable
sensitivity
telecontroller
2.4G: -107dbm@bpsk
5.8G:-103dbm@bpsk
Figure pass
2.4G:= -101dbm@bpsk
5.8G: -98dbm@bpsk
MIMO pattern
SKY
Support for the 1T2R and 2T2R modes
GROUND
1T2R
work pattern
up
Automatic selective frequency hopping
down
Automatic selection of frequency bands
